How many guys deep in the 11's or 10's have ASP pulley?
Just what it says.... is it a mod that is a must to do. How many of you guys that are serious/not so serious drag racers that make over 430 rwhp and run well into the 11's and/or run 10's have them?
The reason why I ask is because I have heard mixed reviews, and I ordered one today almost out of impusle because of them never being in stock.
Did I make a bad decision. I have a 10" JL sub and 300 watt amp.... with factory Monsoon. Will I see any problems?
I only got the crank pulley.
Re: How many guys deep in the 11's or 10's have ASP pulley?
Call ASP for their alternator overdrive pulley. This will allow you to keep the bumpin stereo and still underdrive all other accesories 25%. most people are seeing a 5-9 hp increase on the dyno with this mod. I haven't got to dyno mine since I put the pulley, so I dont have any personal results yet.
It's no problem even with a nice system and no overdrive pulley. I've had the ASP pulley on all three of my F-bodys...including the 9 second one. In all three cars I've run a 10" JL sub and 450 watt amp. Like I said, no problem.
most people get the pulley as one of their mods. Don't worry you did not make a mistake. I don't have a system but the car electrically seems no different than stock with the pulley and like felton said you can get an overdrive for the alternator if you have to.
Excellent mod - feels like car revs faster - good for an easy 7-8 RWHP. No charging issues at all.
I've had mine for about 2 years now and zero probelms. I use the crank and alt pullies, and run a 500 watt amp on top of the 500 watt monsoon system and also use a Odyssey lightweight racing battery
Sounds like a crazy combo, but no problems at all.
The only time you would ever have a charging problem would be at idle...
dont listen to the mixed reviews. get one, if you dont like it get rid of it. I'll bet you like it. I love mine.
