Rear control arms & subframe connectors
I have a 99 WS6 Running mid to low 12's on motor, and mid to low 11's on spray ! But my question is, i found a deal on subframe connectors and rear control arms . If i purchased either of these , would they help,and how ? Would i lose my ride ?
Nope, you wouldn't lose a nice ride at all. In fact, when I installed SFC's on my car, it felt like the suspension was actually doing its job completely, vs. the car acting like a big leaf spring and taking all the bumps. They tighten the whole car up. Not a bad thing at all!
And as for the LCA's, they'll not flex nearly as much as the stockers, and they'll help plant the rear and put the power to the ground better.
You're doing really good to be into the 11's already on stock suspension! Any upgrades you make won't hurt anything. It may not make a "night & day" difference, but the more power you put down, the more you're pushing the stock suspension.
Oh ya, I also noticed that when I get sideways now the car straightens itself out almost immediately
Yup
Helps you use your hp more efficiently
Yup
Did you put in lca relocation brackets yet? LCA's and relocation brackets will help keep the rear planted and more stable on the launch. No stock old rubber bushing deflection. Subframe connectors are probably a good idea as well if you are heading into the 11's and beyond and eventually doing big meat slicks. Not sure what you have now.
I don't know exactly how much the car chassis flexes on launching honestly depending on your setup and times, but they can't hurt you. Plus they make excellent jack points.
Your ride quality might be a bit more noisy depending on what poly or rod ends you get in the lca's. Some people say the ride gets more harsh with SFC's but I didn't experience that personally and don't see how harsh it can get. Maybe its the noise transfer from the rear lca chassis mount point to the front sfc attachment point. I never heard much difference with mine nor noticed a loss in drive quality, but then again I was on a bone stock vehicle at that point.
