Quick Question on 1.85 rockers?
I am going too install new roller rockers and I,m looking at the 1.85's but can I use them with my cam the specs are
224/232 581/593 Or would I be better off with the stock 1.7's? I already have stage 2 heads so springs shouldn't be a issue right?
Re: Quick Question on 1.85 rockers?
You will not be able to use that cam with 1.85 rockers. The lift would be .632" and .645" Your springs will not handle this(unless you have a VERY unusual stage 2 head spring package).. also, it will put a very heavy load on your rollers, likely causing float, or loss of performance at higher rpms (even if the springs were up to the challenge). You'll have to swap in a milder cam if you want to use 1.85 rockers. I hope this helps.
Bryan
Bryan
