Mixing clutch fluid?
Old 05-20-2008, 10:39 PM
jerrad's Avatar
Default Mixing clutch fluid?
From what I've read the fluid is just brake fluid. I guess I'll use dot 3 and am planning on bleeding/adding some fluid. Is it ok to mix the different fluids? I'm not sure whats in it but was wondering if there would be any bad effects to mixing.
Thanks
Jerrad
Old 05-20-2008, 10:50 PM
CW00BlackTA's Avatar
If you are talking about different brands of DOT 3, shouldn't be a problem.
Old 05-20-2008, 11:06 PM
jerrad's Avatar
Cool, thanks alot man.
Old 05-20-2008, 11:19 PM
Black99T\A's Avatar
Yeah shouldnt hurt to mix diff brands, but I wouldnt mix dot 3 with dot 4, if not you should be good
