Belt Size: 8 Rib, D1SC, 3.7" Pulley
Hey guys, I just want to make sure I'm reading this right. Currently I have 4" pulley on a D1-SC with an 8 rib. If I'm looking at this right http://www.exoticperformanceplus.com...html?item=1041 I don't need a new belt (the belt P/N is the same for 370 - 400).
Am I reading this wrong or am I good to use the same belt?
You do have a certain range that a belt will work with. The only thnig you can do is install the smaller pulley and try reusing your belt. Most Napa's keep 8 rib belts in stock, which is where we generally get ours from. Bob
