Belt Size: 8 Rib, D1SC, 3.7" Pulley
Old 05-22-2008, 06:35 PM
'Trust''s Avatar
Default Belt Size: 8 Rib, D1SC, 3.7" Pulley
Hey guys, I just want to make sure I'm reading this right. Currently I have 4" pulley on a D1-SC with an 8 rib. If I'm looking at this right http://www.exoticperformanceplus.com...html?item=1041 I don't need a new belt (the belt P/N is the same for 370 - 400).
Am I reading this wrong or am I good to use the same belt?
Old 05-23-2008, 05:20 AM
EPP
EPP's Avatar
You do have a certain range that a belt will work with. The only thnig you can do is install the smaller pulley and try reusing your belt. Most Napa's keep 8 rib belts in stock, which is where we generally get ours from. Bob
Old 05-23-2008, 03:23 PM
BLNLS1/RX7's Avatar
NAPA part# is 080550.
Old 05-23-2008, 04:36 PM
'Trust''s Avatar
Cool, thanks guys! There is a NAPA warehouse right by the shop that will be doing the work so that shouldn't be an issue. Thanks for the p/n BLNLS1/RX7, that's a ton of help!
Old 05-24-2008, 01:32 AM
firehawk618's Avatar
Just for comparison my setup with a 3.45 pulley takes a 080400. Just a 8 rib 40" belt.
Old 05-24-2008, 09:40 AM
Packy's Avatar
I would go about 39" to 39.5"
Quick Reply: Belt Size: 8 Rib, D1SC, 3.7" Pulley
