Oil change light keeps coming on.
If you dont reset the light when you change the oil, the PCM still thinks you are on the same oil change the last time the light was reset. The PCM doesnt know when you change the oil unless you reset the light. I believe it stays on for 60-90 seconds after the car is started. It uses algorithms to calculate your next oil change based on engine temp, speed, drive time, throttle, etc. Its one of GM's ways of trying to bring the maitenance cost down on their cars....I've seen the GM oil life system let some cars go 15k miles before it tells them to change the oil. Complete BS because some people are stupid enough to believe that its ok.
