strano swaybars?
Old 05-25-2008, 03:37 PM
ZDOG's Avatar
Default strano swaybars?
what type of bushings come with his set? i need to get some grease but dont want to get the wrong type. thanks
Old 05-25-2008, 09:52 PM
Breathtaker's Avatar
Why don't you pm him?
Old 05-25-2008, 10:02 PM
Kleeborp the Moderator™
MeentSS02's Avatar
They are just standard polyurethane bushings. They also come with a packet of grease.
Old 05-26-2008, 07:59 PM
Viper's Avatar
LS1Tech 20 Year Member
You can also buy Energy Suspension poly grease at autozone; I just redid my mounts after 6 years.
Old 05-27-2008, 06:03 AM
Foxxtron's Avatar
Also, according to stranoparts themselves, they say that a good synthetic wheel bearing grease will suffice. Just in case, I'll mention that the grease should be applied to the body-to-swaybar bushings, not the endlinks.
Old 05-27-2008, 11:15 AM
LS1TECH Sponsor
Sam Strano's Avatar
The bushings are urethane.... We do not supply grease with them, largely because so many folks kind of use their own things. Certainly you can use the Energy Suspension grease. I use Redline wheelbearing grease, some folks just marine wheel bearing grease. Basically you want to use something that's not water soluable, and can take some shear load (the bar twisting in the bushings).
__________________
Old 05-28-2008, 04:12 AM
transwiz's Avatar
I used marine bearing grease on mine.Strano hollow sway bars.Got it at pep boys.
__________________________
2000 t/a ws6 with lots of mods
Old 05-28-2008, 10:50 AM
LS1TECH Sponsor
Sam Strano's Avatar
BTW, we do have bars sets in stock, ready to go. Not a ton of stock, but about 8 or 9 sets currently.
__________________
Quick Reply: strano swaybars?
