Question about Bo white TB porting....
that is incorrect, you cannot go over the size of the blade,,you can do whatever you want to the opening,,but when your down to the blade area (the part that counts and is measured) its going to remain the same,,if you go over, your blade will not keep air from coming in.
should only be measured on the blade area,,the front of a stocker is huge compared to where the blade sits,,same with all TB's
FAST 90's and 92"s,,,blade area measurements
etc
i dont know of anyone who would measure the front opening,,that dosnt make any sense,,which is why i do understand why FORD would do it.
etc
