header gasket problem
Old 05-30-2008, 01:43 AM
chucks ss's Avatar
Default header gasket problem
i bought new copper header gaskets and i cant get them to seal , what gives ? its like they arent thick enough , so what gaskets do i go with ?
Old 05-30-2008, 02:16 AM
RrCoX22's Avatar
stock or fel-pro is common as well as cosmetic depending if your heads are milled... did you full smooth the block decks? takes about an hour or two to fully get them smooth if its that first time the heads have been off
Old 05-30-2008, 02:51 AM
95 Z28's Avatar
Header gaskets . I've seen a few people on here that have had problems with the copper ones. Try the GM ones. I got new ones for my headers and they don't leak at all.
Old 05-30-2008, 04:15 AM
RrCoX22's Avatar
Originally Posted by 95 Z28
Header gaskets
wow im sooo out of it, swear i saw head gaskets... well I'll leave the info there in case he ever gets to the heads
...anyways ya the MLS GM stockers will work like a charm
Old 05-30-2008, 07:45 AM
tylerdj's Avatar
I've always used the GM gaskets and had zero issues.
Old 05-30-2008, 10:09 AM
dave70's Avatar
+1 for GM MLS used the ones that came with the car 100xxx miles and had the headers of many times and still on the original gaskets (man i'm cheap)
Old 05-30-2008, 10:10 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
