Made a few 1/8 mile passes last night @ 15psi
Havent been messing with the car much lately so I went ahead and put the 4.25 pulley on the F1A (7.25 crank) and figured I'd see how it would do on a typical 85 degree 70% humidity day around here. DA was 3400' or so, raceweight was 3397lbs.
http://lsx.streetfire.net/video/158b...ad00b8ec15.htm
Not bad for 15psi on a hot, humid day in the mountains. After 30passes or so on the new LS2 it doesnt appear to be makingmuch more power then the old 347. I was hoping the fresh heads and 4" bore would pick up a little but it doesnt appear so. Good thing is it hasnt pushed a drop of water which is a good thing. Nothing too exciting but hey its a free video
Thats mostly my fault not staging the car straight or being out of the groove, it will go whichever way it is pointed pretty darn quick. For some reason I always want to stage it pointing a little left, its hard when you are sitting low in the car and cant really see the hood at all.
http://lsx.streetfire.net/video/b8b7...3a0019f4d4.htm
Tried a 3.50 and the converter got a little too loose for my liking, I need to move up to a 9" converter if I want to run a 3.50, so the 3.70 is back in for now. Yea, the car 60 foots like a low 8 second car, too bad I really dont make any power. But thats the beauty of a centrifugal blower IMO, people complain about the lack of torque but for me it works just fine..
Still learning but do you think your D1SC 60ft harder on the same boost levels as the F1A?? Since the F1A has a higher internal gear ratio opposed to the D1SC's 4.10 would that mean the D1SC makes boost sooner in the lower RPM ranges.
You've experienced with both blowers whats your thoughts?
On the Foot brake how high does it let you stall it too, and what RPM does it jump too?
Sorry for so many questions, lol.
