Little problem with ported tb
Tried the General LSX section but had no luck...22 views.. I guess here it will get more attention. Well I put on my ported throttle body. When I rev it to 1500 or so it does it like normal then when it's going down it will stay at 1100-1200 rpms for 1-2 seconds then go back down to my normal idle. It's not sticking. I think it might be because the Wire that opens the throttle body is not "tight" I can push on it with no effort and it flexes all over the place. Anyone know how to tighten that up or know any other reason why it's holding up the rpms?
if you have a hand held tuner re program your car, thats what i did and it worked perfect mines was doing the same thing i also herd you could try to unhook your batery and then re hook it up but i havnt tried that?
