Ok guys let me pick your brains
Old 06-02-2008, 06:44 PM
417 Motorsports's Avatar
Default Ok guys let me pick your brains
OK heres the deal we are workin on a 37 sedan fiberglass kit car, with a crate motor ls1 t56 setup. ALL NEW PARTS!!!
now the problem we are having is the clutch will not engage. You can push the clutch in and it goes in gear perfect, but when released the car will hardly move. Its weak enough you can start the car with it in gear, without even pushing the clutch pedal in. We have blead it, pulled the trans and inspected everything, and even adjusted the willwood master.
Im outta ideas!!!
You guys have any?
Old 06-03-2008, 04:05 PM
Brad Hutchcraft's Avatar
Clutch disk hanging up on input shaft?
Old 06-03-2008, 07:15 PM
LTLRDSS's Avatar
what clutch you may need a shim
Old 06-04-2008, 07:32 AM
wrencher
wrencher's Avatar
Is that willwood master adjustable?
Is it adjusted properly?
Something has to be keeping the pressure plate from fully clamping the disc if it slips that bad.
Quick Reply: Ok guys let me pick your brains
