Tuning Questions about injectors....
Restricted User
Ok, picked up some Accel 30# used, for free! Looking at the website, they rate at 30# @ 43.5psi, so with our psi I figured about 34#, is this correct? Also, what all has to be adjusted in the PCM tuning to use these? How would it react if not tuned right, will it be rich, lean, or stutter etc...? Other than the injector flow rate table (is this right?) is there any other tweaking for timing of the injector pulses etc... or is that like a Ed Wright kinda thing
Thanks.
Thanks.
