LS! install in a 95 silverado 1500
Well i was thrilled when my dad called me and said son I need a LS1 in my truck. Well here is the question. What will it take to drop it in there? Money is not really a issue but would like to keep on a decent budget. I have LS1 heads off my 2000 camaro SS. IF anyone could give me some advice it be much appreciated.
You will need a complete LS1 engine with wiring harness and PCM. You need truck oil pan with oil pump pickup tube. Depending on your transmission, you may need an adapter plate. You will need new engine mounts welded to your 95 chasis.
Get in touch with advance adapters or Novak. They can set you up with what you really need.
F-body oil pan works fine. Easy to fab engine mounts to bolt right up to your existing frame mounts. S & P "G-body" headers fit nice. F-body fans fit perfect, send out harness & computer to delete EVAP, VATS, Set Speedo VSS to your trucks speedo, speed limit delete, better engine tune ,etc. Go to www.LS1Truck.com for info from people that do nothing but these types of swaps.
