Changing engine. need to change tune...
I'm swapping out my engine this weekend and would like to have a tune ready to go in.
I have LS1edit and current tune is for stock displacement head/cam engine.
I'm going to swap in a 383 with 42lb SVO's
Can someone give me the values needed to adjust for the larger injectors.
I'm sure changing displacement will not be a problem..lol
Are there any other tables that need to adjusted besides the injector flow rate?
I can supply a copy of my current file if it will help..
Thanks
Thanks
I swear I mean this in no arrogance, but this section is more geared towards teaching you how tune your car rather than having it done for you. There are sticky's up top and tons of threads that address specific issues. I read and read and read and read when I got started. Get a wideband right away.
