Tcc and abs issues with 9 Inch. Help Please!
Old 06-04-2008, 03:19 PM
Sweet71's Avatar
Default Tcc and abs issues with 9 Inch. Help Please!
I just finished my car and got it out, over winter i did a moser 9 inch with 31 spline axels, a detroit tru trac and kept the relucter rings to retain abs and tcc.
Just finished the car last night and the ABS inop light is on and it keeps throwing a traction contol code, When you hit the brakes they pulse like the abs is kicking on, then once the light comes on the brakes are good to go. has anybody ever had issues with the moser relucter wheels? Any Help is greatly appreciated! Thanks
Old 06-05-2008, 12:05 AM
roy
roy's Avatar
Check the wiring from the rear bulk head connector to the sensors and then check the sensors.
Mine was PnP with no isues.
Old 06-05-2008, 07:38 AM
YellowToy/A's Avatar
I had to remove the sensors and replace. All looked well. I just pulled them out and put them in and it has worked ever sense.
Old 10-02-2008, 03:20 PM
Souless's Avatar
Sweet71, did you ever get this fixed? I am having the exact same problem.
Old 10-02-2008, 10:05 PM
Souless's Avatar
Can anyone else help with this? I seem to be having the same issue. I pulled my sensors, cleaned them, and tested the voltage, they are both showing 4.79V. Am i missing something do i need to re-bleed them?
Oh BTW, these are the codes I am getting:
PCM] P1637 - Generator L-Terminal Circuit (Pending) (History) (Immature)
[PCM] P1639 - 5 Volt Reference 2 Circuit (Old) (History) (Current) (Immature)
[Brake] C0245 - Wheel Speed Sensor Frequency Error (History)
[Brake] C0046 - Brake Pressure Sensor A/B (Current)
[Brake] C0051 - Steering Wheel Position Sensor (Current)
Old 03-30-2011, 06:14 PM
01Blk*SS*'s Avatar
Did any of you guys ever get this fixed? Im having the same problems with a Fab 9 at above 60MPH
Quick Reply: Tcc and abs issues with 9 Inch. Help Please!
