right rear noise
Old Mar 28, 2011 | 07:19 PM
keith102371's Avatar
Default right rear noise
I have a whywhywhywhywhy noise coming from my right rear wheel, sounds almost like a mudgrip tire,
Axle bearing? I dont think its a bad tire.
Old Mar 28, 2011 | 08:14 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
It probably is the wheel bearing. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 28, 2011 | 08:22 PM
FirstYrLS1Z's Avatar
wheel(axle) bearing or right side carrier bearing,they both produce a similar sound/noise when they're going/failing.
Old Mar 28, 2011 | 08:31 PM
any way to tell with out tearing it apart?
Old Mar 28, 2011 | 11:30 PM
CamaroZ28_LS1's Avatar
Jack the car in the air and run it in the air and listen for it with a Automotive stethoscope.
Or a screw driver against your ear.
Old Mar 29, 2011 | 12:39 AM
FordHater's Avatar
x2 on that one
Old Mar 29, 2011 | 04:52 PM
checked today, its a axle bearing.
Old Mar 30, 2011 | 06:27 AM
what is a good brand to get? Timken, National or other?
Old Mar 30, 2011 | 07:35 PM
FordHater's Avatar
I've never had a problem with Timken, if you do the work yourself its definitely worth the "risk" for the cheaper ones in my opinion.
Old Mar 30, 2011 | 08:14 PM
TurboStangJON's Avatar
A good way to check is get going down the road and unload that side by swerving slightly. I said slightly so don't run into another car and if the noise goes away it's an axle bearing. When you take it apart be sure to check the axle for pits otherwise you'll just end up in the same boat.
