SES code p0102
Old 06-07-2008, 06:54 PM
Hantzum's Avatar
Cool SES code p0102
I just upgraded to a TH350 with transbrake steel tube drive shaft and moser 12 bolt with 373. Drove around town just fine but when I went to run at the track last night I threw p0102 after first pass. Used Hp tuners to clear the MAF low voltage code and it immeadiatly came back. The engine fuse 20 amp was fried so I replaced there on the spot and cleared the code. As soon as I started it, code came back and the fuse was blown again. Looked under the car and the O2 sensor extensions are both fine, no melting up against the header or anything. The MAF is pretty new. SLP 80mm MAF, haven't tried cleaning it yet but any ideas if that doesn't work.
Old 06-07-2008, 07:54 PM
sreve's Avatar
there is still brake lights and the trans that could be a player.
see the P.D.F.
File Type: pdf
