what boost levels for 408
Okay so i got my built 408 with a cr of 8.8-1, with a232 226 dur.@050.588 and a 574 lift on a 114 lsa @110 cam, now was wondering what boost levels what be good for this cr???Mostly street car, pump gas...oh yea i got a gt 76 garrett in a rear mount setup....any advise or opionions...thanks
Check out this Camaro we built. Bob
http://www.exoticperformanceplus.com...Car.php?car=32
New video footage inside at bottom! We upgraded Scott's car with a 6.0L iron block, now displacing 408 cubic inches. We are still using the 4l60 transmission and Vigilante 3200 converter, and Scott still has the 3:73 gears. We installed a larger GTS76 mm turbo, a 44mm wastegate, and an E-boost 2 controller. We added a larger K&N air filter, and we made a 4.00" exhaust tailpipe for it. This new set-up is definitely going to make a lot more power. We're out of injector at 11.5 lbs of boost, so the next step will involve installing a driver and some 95lb fuel injectors.
hey bob what you think about those 79lbs injectors from ractronix's,those 60 max at around 11lbs on his setup would those 79's be any better???
yea i dont think ill be doing that.......those gaskets are pretty expensive.....
A 79lb high impediance injector would be a great idea, I'm not sure what their cost is, but Delphi 96lb injectors and an AEM driver run $800.00 combined. They my not be too much more. Bob
