braided clutch line on header..
Ok, i figured it was going to be close, but its actually up against the header, (the braided line going from the master cyl into the bellhousing, my question is how could i keep it from boiling the fluid or whatever is going to happen to the line itself? nothing close enough that i could see to tie it to to keep it off of it, and im not 2 sure if some kind of rigged exhaust wrap would help it that much either , but i'm open to suggestions, not going to be driving the car until its fixed...
also off topic, after installing the (headers/ls6 intake/wires,plugs/!air!egr/!rear 02's) why would my knock sensors be throwing codes?
thanks alot,
michael
thanks alot,
michael
thanks alot,
michael
thanks alot,
michael
is there any kind of wrap i could use that doesnt involve me disconnecting the quick disconnect? i hate that thing... (dont have the correct tool for it) lol
and is there no complete way of keeping the heat off of it? so i dont have to change the fluid so often?
1 Post
+1 for screwdrivers, i hated that fitting at first too until i found out how easy it was to do, u just hav to push hard enough on the white clip and bam that sucka is out!
the only kind of wrap i could find was for spark plugs.. it is a heat shield sleeve looking thing tho, and it looks like it'll fit over the wire, think it'll work? and how often should i change my fluid? and does that mean just bleed it? or change all the fluid, i doubt i'll put 3k miles on it within 2 or 3 months,
