refill AC
refill AC
Hey guys i broke this ac line when doin H/C and i got a new line and just wondering how to fill it back up the auto parts store said to buy the referent stuff and this oil that is only four bucks but wondering if i need the oil cuz shouldnt it still be in there or would it have came out as well
Too much oil and it won't cool as well. If you just put refrigerant in without using a vacuum pump it won't cool as well.
So there are two things taking away from your AC systems performance.
You shouldn't need oil, just pull a vacuum and put the proper refrigerant charge in it.
Rated at 5 cfm or higher.
Very true. People see oil buildup around the exhaust port of the pump, it's the vacuum pump oil.
Vacuuming? It's called evacuation to avoid confusion.
It's looses ABOUT 2 oz. So what do you put ABOUT 2 oz back in?
In this peticular post the guy broke the vacuum line, there was no recovery, no oil is lost during evacuation, so Don't add oil.
