how to calculate speed from rpm
Old 06-14-2008, 04:12 PM
wave1957's Avatar
Default how to calculate speed from rpm
Could someone please tell me how to calculate car speed from the RPM? my speedo is not connected yet...
Also, does someone know the gear ratios for a 4L80E?
Thanks
Old 06-14-2008, 04:34 PM
fouz65's Avatar
http://www.f-body.org/gears/
Old 06-14-2008, 04:38 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Assuming you want velocity in MPH and you use inches for the tire diameter:
PI*Tire Diameter*Engine RPM/(1056*Diff Ratio*Trans Ratio)
Old 06-14-2008, 09:07 PM
Scooter70's Avatar
Excel sheet
Change the yellow boxes for your rear tire and the gear ratios to match your A4.
Old 06-14-2008, 10:28 PM
dman's Avatar
this is a formula i use mostly to calculate what RPM i'll go thru the traps at.
mph x 336 x final drive ratio / tire size (diameter)
130 x 336 x 3.08 / 25.5 = 5276 rpm
dman's Avatar
btw 336 is the constant
Old 07-31-2008, 02:16 PM
redemn93's Avatar
when considering an A4 car, how do these calculators work as far as converter slippage? are they less accurate? is there anyway to factor that in?
Old 07-31-2008, 03:13 PM
dman's Avatar
you can factor it in if you know the amount of slip.
Old 07-31-2008, 03:48 PM
redemn93's Avatar
how do you figure out the amount of slip? ask the manufacturer or is there a way to test it?
