What is this, and do I need it?
I am currently building a car that uses the C5 Vette trans/diff combo mated directly to a 5.3L from a 99 truck. I thought I found all the wiring information I needed here, until I came across the following picture (borrowed from E. Green on Corvetteforum):
This is a picture of a C5 trans. Can someone tell me what the black module is? I am assuming that it is a gear shift position indicator, but I haven't seen anything like this on any wiring diagrams. I know the Corvette shifter is shorter than the F-body because of the torque tube, so I was wondering if this module is normally in the console of a F-body. However, I haven't seen anyone mention the need to hook up any wires to this. So, what is this and do I need it? The trans I bought didn't have this attached.
Complete setup details:
99 5.3L engine with LS1 intake mounted backwards
98 C5 4L60E
99 truck engine wiring harness
00 truck fuse box
Thanks for the help.
Ken
98 C5 4L60E
00 truck fuse box
Ken
It is definitely the gear position indicator; called the "PNP". If the ECU expects it then you need it if the car going to be manual or auto. I ran into this when we converted a H2 to manual transmission. We ended up just putting it in Neutral and hiding it out of the way. Here is the diagram for it on a 05 Corvette.
