Alignment w/ Strano springs?
I know alot of ppl on this board run strano springs. I was just wondering if they ever gave anyone problems when they got the car aligned.
I have new rims and tires as well as strano lowering springs. I installed the rear springs and am about to install the fronts but I noticed that there is no easy fix if the wheel bows in, the tires would be garbage very quick.
Let me know if Ill be fine. I dont see a problem since sooo many ppl have them and I havnt herd of anything like this.
thanks
thanks
Well the difference between stock springs and stranos are pretty big in size. I was told that I would have to get it aligned after installation. I was just wondering if anyone had problems getting there car aligned after install. Forget the bowed in coment.lol
I am lowered 1 3/4" around, do my align ( did this for over 30 years), no problem getting total align, I get 0ver 35 k miles on my tires with only perfect wear ,no way any one can see differance in wear from front/rear or left/right. I run + 0.40 camber/both sides,+ 4.00 left ,
+4.50 right for caster, +1/16" toe,with air @42-44 psi ,and I will state again any one may examine my ties for wear,they are perfect wear
.02's Johnny
.02's Johnny
My car was pretty close to perfect after installing my Stranos. I run about .5 degree of negative camber which works out great for me. And btw, camber doesn't wear out your tires, tow does so mark sure your get your tow set as close to zero as possible.
