how do i tell what gears are in the rear end?
Old 06-19-2008, 07:25 PM
barryta33's Avatar
Default how do i tell what gears are in the rear end?
just got a rear end from the junk yard how do i tell what gears are in them? where is the stamping?
Old 06-19-2008, 08:09 PM
barryta33's Avatar
Any one ?
Old 06-19-2008, 08:42 PM
blue98Z's Avatar
Most that I have seen are on the end of the pinion shaft. Just divide the big number into the little. If it doesn't have the #'s stamped on the end then just count teeth on the ring and pinion gears and divide. Ex. 39/9= 4.33
Old 06-19-2008, 09:43 PM
chuckyt1's Avatar
Spin the axles and count how many times the yoke spins with one turn of the axle. If it goes around 3.4 times, it's a 3.42, 3 and 3/4 turns - 3.73, etc... Unless you have the cover off, then just do the division like was said above.
Old 06-20-2008, 05:22 AM
72ChevelleConv.LS1's Avatar
Take the cover off and on the side of the ring gear it is stamped. it will say somthing like 57:10 then you devide the 57 by 10 and thatis = 5.7 or 5:70 ect...
Old 06-20-2008, 09:32 AM
barryta33's Avatar
thanks guys !!
