how to reinstall stock rockers?
I changed the pushrods, some bent valves and springs. Now I need to figure out how to correctly torque down the rockers. I set it up so cylinder 1 is at top dead center, now were do i go from there?
little bit of advice...if you soak your lifters in oil first, don't just torque the rockers right to 22. Snug them down with a small ratchet and stop when you start feeling resistance...you'll hear them bleed down....then after a little, tighten them some more....ect....until you bottom the head of the bolt out. Then tighten to 22 lbs....rotate...then check 22 again....
