LSx Engine w/ Autometer Tach Question
Old 06-20-2008, 07:07 PM
Mike96z's Avatar
Default LSx Engine w/ Autometer Tach Question
I was just wondering, if any of you who hooked your LSx engine up to an Autometer Tach, did you have to use the 9117 Tach Signal Adapter? Is this even neccesary?
http://www.autometer.com/cat_accesso...il.aspx?vid=99
There is the link, in the instructions the LSx engine is listed but I know there is also a tach signal, its a white wire coming out of the PCM, and it also is accessable through the passenger side kick panel in one of the connectors. Any input is great. Thanks
Old 06-20-2008, 09:24 PM
babydeuce's Avatar
I run this tach http://www.autometer.com/cat_gaugede...id=2831&sid=15 with my 5.3 off the PCM tach signal wire. It works fine, just a bit "bouncy" under 1K RPMs.
Jack
Old 06-20-2008, 09:37 PM
Mike96z's Avatar
mines the sport comp, 5" silver with shift light, i hooked it up using that tach signal wire but no luck. It didnt show any rpm's at all, its similar to yours and should work the same. i forgot which wire it is on the pcm, i think its PIN 10 or something on the blue side. I believe that same wire runs through the pass side kick panel and into the guage cluster, this is where I tapped my wire, maybe I should tap it at the pcm? Thanks
Old 06-22-2008, 02:20 PM
Mike96z's Avatar
Jack
so do you know where I should be hooking my tach on the PCM?
Old 06-22-2008, 09:27 PM
babydeuce's Avatar
I wish I could give you a direction to go, but I am using a painless truck harness and PCM on my 5.3L. I just used the wire that was labeled for the tach, and mine works fine.
Jack
