Largest Cam wit tsp prc stage 2.5 5.3's milled to 59cc
Old 06-22-2008, 06:59 PM
ScreaminBird99's Avatar
Default Largest Cam wit tsp prc stage 2.5 5.3's milled to 59cc
i have a 224r cam from texas speed and made good power, however i want someting with a little more wicked sound, was wondering what is the largest i could go with heads i listed in the title, texas speeds prc stage @.5 5.3's milled to 59cc
Old 06-22-2008, 09:22 PM
bump, need help
Old 06-22-2008, 11:24 PM
Emoney97ss's Avatar
i wanted to run a f14 and was told by everyone that it would fit... tsp said that they had some cases where a tv2 would work but was extremely close... the specs are something like 230/232 .598/.598... don't quote me on those specs but they should be close... if you want something much bigger i would say to fly cut the pistons and pick any cam that you want...
Old 06-23-2008, 09:34 AM
Thanks man, i think ill just stick with the 224r, i made around 405 to the wheels cam only with full bolt ons
Old 06-23-2008, 10:21 AM
00 Freak's Avatar
that's some stout numbers. I would just stick w/ that cam also.
Old 06-23-2008, 10:33 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I would fly cut anyways, since the heads come off, its not hard to do BUT the guys who already have head work done and swapping bigger cams out, thats the issue especially since they dont want to touch the heads.
Old 06-23-2008, 10:28 PM
PREDATOR-Z's Avatar
No freaking way anything bigger than your cam will fit with safe PTV clearance.
Old 06-27-2008, 04:20 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We typically only run the 228R with 59cc heads. After that you MUST check p/v because it will be really really tight!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 06-27-2008, 04:32 PM
racer77ss's Avatar
a cam that whould give notisable improvment would need flycut pistons for ptvc
Old 06-27-2008, 05:10 PM
LS1C5Vette's Avatar
Originally Posted by racer77ss
if you want any notisable improvement you will have to flycut
That makes no since.
Old 06-27-2008, 05:44 PM
racer77ss's Avatar
ya that didnt make since
Old 06-27-2008, 06:38 PM
Fratsit's Avatar
I am running the 228r with those heads and still flycut, just to be safe.
Old 06-27-2008, 07:53 PM
tpduke112's Avatar
sense. and no it didnt make any.
Old 06-27-2008, 08:14 PM
HavATampa's Avatar
^^^ LOL ^^^ You took 2 out with one shot. Nice tpduke112!
Old 06-27-2008, 10:55 PM
Silver 2000 Ram Air's Avatar
what kind of numbers/times are you doing with that combo?
Quick Reply: Largest Cam wit tsp prc stage 2.5 5.3's milled to 59cc
