Pump not running, tank reads E
I just put about 5 gallons of fuel in the car, so I know it's not empty. The pump won't prime and the gauge reads E. I've swapped relays around, checked all the fuses I know to check, I'm lost. I'm pretty sure it's not a dead pump since it just quit all of a sudden. I'm pretty sure I'm losing power to the back. Any ideas on what to check?
pull the FP fuse & complete the circuit by sticking a wire in where the fuse was.
That will tell you if the pump is good/bad....
If pump works this way, than maybe the the FP relay inside the PCM blew...
