Will a vacuum leak cause a high idle and surging?
Old 06-25-2008, 08:57 PM
98RedBird's Avatar
Default Will a vacuum leak cause a high idle and surging?
I just got the motor FINALLY together and running with great oil pressure but the tune seems a bit off. It drives okay but seems to idle really high and then moves up and down from like 1300-2300RPM. It's with the mods in sig. Also, when driving and letting off the gas it jerks almost like a really big misfire or like it's running out of gas (this might be what is called bucking I'm not really sure). I'm just wondering if maybe there's a vacuum hose that I forgot to hook up on the intake or something that might be causing this? I'm not going to mention who tuned it because I'm not sure if it's in the tune or if it's my fault.
Thanks guys.
Old 06-25-2008, 09:11 PM
Soul TKR's Avatar
If you had a vacuum leak you would most likely hear some sort of whistling noise... it would definatly cause idle issues if you had one... But most likely it's in the tune. What kind of throttle body do you have?
Old 06-25-2008, 09:20 PM
98RedBird's Avatar
FAST 90. Well here's what I'm wondering, I just realized that when I deleted the HVAC that I didn't plug the rear plug on the intake that controls the switching of air flow in the cabin to the floor. I don't hear a whistling but then again, it was running open headers so I probably wouldn't hear the horn if it was going off...
Old 06-25-2008, 09:36 PM
98RedBird's Avatar
The other thing is that port is right in the area of the MAP sensor, maybe it could be throwing off the reading for the MAP?
Old 06-25-2008, 09:46 PM
nobreaks254's Avatar
I have a similiar problem with my new build. I'm pretty sure I dont have any vacuum leaks. But I have the same symptoms as you. I would think you need to plug the port at the back of the intake.
Old 06-25-2008, 09:56 PM
98RedBird's Avatar
Yeah, I know. I need to do that regardless. Sounds like it's in the tune though...
Old 06-25-2008, 11:15 PM
98RedBird's Avatar
Yep, nevermind, I just checked and all of the vacuum lines are plugged in and ready to go... Must be in the tune. How do you fix the idle issue though and why does it do it? It's just all over the place, up, down, idles great for a few seconds, then shoots back up to like 2000, then just hangs there....
Also, I'm a little worried about the bucking issue. I'm not even sure that's what it is, but I'll be driving along with the throttle down a little bit just cruising and it'll start jerking forwards almost like it's trying to die, then it'll clear up and drive fine for a little bit...
Old 06-25-2008, 11:33 PM
johnLs1camaro's Avatar
did you remove all of your air and e.g.r bullshit?? i had the same issue with the because my hose that went into the top of the intake manifold had a leak and it caused the same issues due to loss of vacuum and then i removed all of that **** and it fixed everything...
Old 06-25-2008, 11:41 PM
Soul TKR's Avatar
do you have any sort of hole drilled in the throttle body blade?
Old 06-25-2008, 11:45 PM
98RedBird's Avatar
I did remove both my AIR and EGR. But all of my hoses are gone and they've been tuned out.
No, I don't. I wish I could get this figured out though, this engine build has been headache after headache so far it seems. If it's in the tune, I'll just send the PCM back and see if they'll fix it.
Old 06-25-2008, 11:46 PM
ok i didnt know if you still had the stuff on there....so you have a send off tune where you mail your pm??if so i would really recommend getting a dyno tune from a local tuner or something..
Old 06-26-2008, 02:51 AM
98RedBird's Avatar
I know, I would recommend that for me too... But the nearest tuner is like 3 hours away and I bought the head/cam package from this sponsor that I have the Mail Order Tune from so I figured they'd be able to hit it pretty darn close.
Old 06-26-2008, 08:06 AM
Let me know what you find out. Sounds like we have the exact same problem. We also have similiar setups only mine is a 383. We probalbly have the same sponsor mail oarder tune too.
Old 06-26-2008, 09:06 AM
98RedBird's Avatar
PM me who did your tune. I'm curious. I'm going to call them this morning.
Old 06-26-2008, 09:12 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Have you tried to adjust the idle set screw on the TB? Most people assume they are set perfectly right out of the box, and that's not the case all the time. You might need to back it off a bit.
I'm not sying it can't be the tune, but yours is a straight forward every day set-up that Jason tunes daily. He usually hits them pretty close on the first try! I'd make sure there are no more vacuum leaks as they wreak havoc on several systems! Let me know if that doesn't clear it up, and we'll figure it out one way or another!!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-26-2008, 12:40 PM
YellowToy/A's Avatar
It is a vacuum or exaust leak. Look harder
Old 06-26-2008, 12:42 PM
98RedBird's Avatar
I'm beginning to wonder if it's that damn MAP sensor on the FAST intakes. Come to think of it, it was doing a little bit of surging after the FAST install a few months back, just not as intense as it's doing now. I never RTV'd it or anything, and it was kinda loose in there. Maybe that's the problem here.
Old 06-26-2008, 01:02 PM
98RedBird's Avatar
I went ahead and RTV'd the MAP sensor and reinstalled it. I'll give it some time to setup and we'll see what happens later tonight.
Old 06-26-2008, 01:32 PM
stevied916's Avatar
buy a couple cans of carb cleaner and spray all over the vaccum lines...you will probabally find a leak somewhere
Old 06-26-2008, 01:38 PM
07gsxr750's Avatar
its probably that map sensor, mine was loose and fell out a few times before rtv.
Quick Reply: Will a vacuum leak cause a high idle and surging?
