Got a few issues to work out, need feedback
I just picked up an '02 WS6...When I turn on the headlights, they flip open and won't stop so I get that loud jamming noise for a few seconds then finally stops....How do I fix that? And what size bulb do the headlights use? One of the bulbs is out. I don't have an owner's manual.
What are common problems with the power seats? Mine don't work.
The owner put a textralia clutch/flywheel in. Is it normal to hear a short whirring noise when going from a stop? Maybe any vendors can shed light on this?
Any feedback is appreciated, thanks.
Location: Your girl's back door giving her the long stroke while you're at work
See the thread below about the headlight noise
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
The headlights are sealed beam(I think), a new one is $25 at Wal-Mart
Check the pwer seat fuse in the fuse panel inside the car. It's silver, replace it and see if that corrects the problem
*The headlight issue is due to the motor needing adjustment.
*+1 on the pwr seat relay/fuse.
*I'm running a Textralia with no noise issues. I do have issues when it's cold outside, but still no noise from it. It sounds like your slave cylinder needs to be replaced.
Cool, thanks for the info...which fuse am I looking for?
I'm going to bring the car to a shop to look at the clutch issue....in first gear when you roll off the line it whirs for a second or 2.
ok, so I took off my headlight and I'm ready to rotate the motor shaft 180 degrees.
But how the hell do I know how far the motor shaft is turning??
Ok, I'm a newbie to this car...how do I check the relay? I'm not sure what I'm looking for.
