Any way to change horn sound?
put your hand over the horn end (where the sound comes out)
you will be able to tell which is working
also you may not need a new horn.......
Pull both horn clean the contacts where the wire connects
and contact where it bolts to the body/bracket
dont forget a little electrical grease
I did this on mine, now its back to normal
both horns working and sounding good.
One of my horns got to much water in it and crapped out. I went to O'reilly's and got a basic replacement horn for the high and low. Now its twice as loud as it was when both stock horns were working.
