turn signals not working
1. If you get a solid non-blinking arrow on the dash, it probably isn't the bulb. The signal will flash fast if your bulb is burned out.
2. If your hazards blink, it isn't the flasher fuse.
3. The front sockets will usually looked burned for some reason. A replacement socket from the dealer costs $70. A replacement socket from AZ is $8. If you don't want to cut the leads, the white plastic insert comes out of the gray socket and you just replace that part by carefully using a small screwdriver and needle nose pliers.
4. If your bulb is burned out, the replacement is 3057. I use Sylvania instead of cheaper ones because the base on a cheaper brand was practically melted off in one socket.
http://www.sylvania.com/ConsumerProd...RG-Results.htm
5. There is a way you can check to see if your DRL module is bad. Here's the link.
http://www.camaroz28.com/forums/show...ght=drl+module
After I did this, I took mine out and opened the box and found where the "funny" electrical smell was coming from. One of the soldered links was melted for some reason. A replacement from the dealer cost $300. I got a used one from eBay for $40. The part number is 10407669.
its easy all you have to do is cut 1 wire at a time if you want and wire it to the new socket.
you can get the socket at autozone for $8.
(oh yeah, the DRL is right behind the radio. CAREFULLY pull the HVAC/Radio bezel off, a few screw from the radio mount and there it is, mounted on the firewall.).
