Msd Window switch
Msd Window switch
Well I just installed my nx wet kit and I can't get my window switch to activate the system. I've bypassed my fpss and still no results and finally bypassed the window switch and the system would finally activate. I've double checked the wiring and found no problems. I was wondering if the tach signal is to weak to activate the switch. I've spliced into ecm for the tach wire. Any help would be greatly appreciated...
I had the same problem with the MSD box. IMHO it's junk. Get yourself one of these bad boys. Awesome and easy install.
PN TPP-00011 Dual Window Switch
http://www.trickperformanceproducts.com/tpp_00011.htm
http://www.trickperformanceproducts....ndowswitch.htm
