Nitrous Oxide - Need help figuring out wiring on older FJO 908 RPM WINDOW SWITCH
stevegrizzle
06-30-2008, 07:03 PM
Well I seem to have bought an older model and the wiring diagram on the fjo site is only for their new one. mine only has 5 wires instead of six.
If someone could just tell me if I am right or not that would be a huge help.
wires are:
Black- ground
Red- power
green- tach signal
and two white wires, I am assuming one for each stage.
Can anyone confirm this for me?
Thanks,
Steve
860 Performance
06-30-2008, 08:06 PM
Sounds like you have the ZEX one (made by FJO for ZEX)
Its single stage and has different wires than the 908
http://www.zex.com/Base/Images/Products/400_235-TractionSwitch.gif
stevegrizzle
06-30-2008, 09:03 PM
Ahhhh, strange bc it says 908 on the bottom of mine. but that is def it in the picture. but it is a dual stage.....only using one however
860 Performance
07-01-2008, 06:09 AM
It dosent have enough wires to be a 2 stage. Two stage needs the following:
white-power
blk-ground
yellow-stg1
orange-stg2
blue-tps
grn-rpm
Take a look at these instructions:
http://www.zex.com/Base/Instructions/ZEX169.pdf
stevegrizzle
07-01-2008, 06:29 AM
Yes I looked at those.
Here is what it says on the bottom of my window switch:
"CWS0908 SER#1100 908 Window Switch, Dual Channel"
That is what is confusing me.
Thank you very much for the help.
stevegrizzle
07-01-2008, 06:49 AM
From looking at the wiring diagrams I see that does have the correct corresponding wires.
My last question is, does it matter which of the white wires goes to either the wot switch or the relay?
860 Performance
07-01-2008, 08:17 AM
No it dosent matter which white wire, they just gain continuity when it activates.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
