Lt1
Old 06-30-2008, 10:00 PM
Choppers's Avatar
Default Lt1
If the optispark or iginition module goes bad will the motor turn over? this guy says the igintion module is bad and thats why the car won't run. has 168,000 miles.
Old 06-30-2008, 10:12 PM
GLT1's Avatar
It has to turn over at least,often when the opti is bad it will start and die or not start but turn over however if the ignition module is bad then yes it wont turn over,but it does have 170,000 miles,i say move on or have him fix it and if he does buy it if its cheap.
Old 06-30-2008, 10:15 PM
Choppers's Avatar
how much are ignition modules and are they hard to replace. i thought the ingnition module was the optisprak but guess i am wrong. he says the igintion module is $75 is this true? what does the module actually do and is there a way to tell if ones bad. i am looking at this car. it has 168,000 miles and has leather interior and is a 95. how much do you think its worth he says it needs some work. hes asking $1000. is it worth it?
Old 07-01-2008, 02:38 AM
LT1
LT1's Avatar
Its called "ignition controll module" mounted on driver side head, if its bad the engine will crank and no start.
Ignition controll module is about $50-$80
Ignition controll module gives pulse signal.
i would first check for spark, then coil, spark plugs, wires, before replacing the ICM.
Old 07-01-2008, 09:52 AM
Choppers's Avatar
so your saying either way that motor should turn over even if the optispark or ignition control module is bad correct?
Old 07-01-2008, 10:18 AM
Choppers's Avatar
he said the motor wouldn't turn over right now and its the result of the igintion. do you think he is telling a lie or what?
Old 07-01-2008, 11:05 AM
djjab57's Avatar
if the ignition control mod is bad YES it will turn over If your ignition switch is bad (sits on top of the steering colum) it probably wont turn over
Old 07-01-2008, 12:13 PM
Choppers's Avatar
ok i think i am going to go over there and try to turn the motor over by the crank to see if the motor may be locked up cause i don't want to even mess with it if the motor is locked up. being it has that many miles it could be internal problems.
Quick Reply: Lt1
