Evap Purge Valve
Evap Purge Valve
Do any of your purge valves have a 5mm play at the ends? Is it supposed to fully tight?
When I checked this valve on another TA, it was completely tight with absolutely no play. In the bottom pic, the distance between the yellow ring cap on the intake end and the illuminated ring directly above is the available space that the piece is able to slide in and out (about half a cm).
I think so but i haven't had any codes come up yet. There is something weird going on with my car so im gonna autotap it eventually it still doesn't feel right still seems like it has a misfire.
