How should it idle with these disconnected?
Old 07-02-2008, 10:33 AM
ssduane's Avatar
Default How should it idle with these disconnected?
Getting ready to fire up my build. My PCM has be tuned to the engine and I had them leave the MAF and IAT in the program. I don't have a MAF yet or the IAT sensor. Once I fire up my engine what should I expect? Any hunting, high idle etc.... Or should it run good? I do have my digital dash hooked up to the check engine light, so I expect to see that. But should expect any erratic engine operation?
Thanks
Old 07-02-2008, 10:37 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
It will likely idle pretty high for a while, then really low. It's not consistent how it will idle/run though so you can't say for sure.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 07-02-2008, 08:01 PM
ssduane's Avatar
Another question? IS the plug connectors there same for 98-00 and 01-02 MAF's? I have a 99 harness (I think) and an 01 PCM. I know there are two different MAF's out there so was just wondering.
Old 07-02-2008, 08:31 PM
9 Second Club/LS1TECH Sponsor
Speartech's Avatar
For F-bodies they are all the same 3 terminal connector (99-02). The Corvette went to the 5 terminal MAF in 01 (like the trucks use).
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
