98 ls1 computer compatible with 98 trans and 01 ls1?
Old 07-02-2008, 02:26 PM
WithStrengthIBurnxx's Avatar
Default 98 ls1 computer compatible with 98 trans and 01 ls1?
im asking this for a friend
he asks,
is the 98 ls1 computer (i think from an f-body) compatible with the 01 ls1 service engine and 98 4l60e?
he says he is getting no spark coming out of the coils, yet he has continuity there..?
Old 07-02-2008, 10:18 PM
sawzall wielding director
G-Body's Avatar
Yes but no. If he is using a 98 computer and wiring harness with 98 sensors to control a 98 trans and 01 LS1 then yes it is. If he is trying to plug a 98 PCM into a 2001 harness then it will not work.....he would have to re-arrange most of the 160 pins on the PCM connectors.
Old 07-02-2008, 11:08 PM
98catfish's Avatar
Short answer ...... Uh, no
Old 07-03-2008, 01:50 AM
88s10's Avatar
G body is correct it will work with a 98 harness. The only sensor you will need is a 98 temp sensor
