Driver's side view mirror shaking...
Old 07-04-2008, 09:37 AM
johnh's Avatar
Default Driver's side view mirror shaking...
Ok..I know its a little thing..but my driver's side view mirror shakes quite a bit when driving...the passenger one rock solid.
Any ideas on how to fix this? I don't want to try to replace the whole thing
My present idea is to put some rubber weather stripping inside the mirror housing to minimize the bouncing/shaking..
Old 07-04-2008, 09:15 PM
ikaros23's Avatar
I have the same problem jajaja it gets worst when pass 60mph
Old 07-04-2008, 09:53 PM
SparkyJJO's Avatar
My passenger one does that. The one mount inside is broken. peek between the mirror glass and the mirror housing at the bottom and see if anything looks loose or broken.
Old 07-04-2008, 10:24 PM
2002_Z28_Six_Speed's Avatar
You can very easily take the mirror glass out. It is just on two pegs and a cross like metal bar. Very easy to reinstall.
Old 07-05-2008, 12:30 PM
Pewterpower's Avatar
Can you explain how to do that in a little more detail?
Old 07-05-2008, 05:23 PM
wickedformula's Avatar
mine does it too. passenger mirror unfortunately is falling off though. metal mount broke inside. good luck with the fix. i live with it. subwoofer will shake em anyway
Old 07-05-2008, 07:59 PM
what aspect?
Old 07-05-2008, 09:05 PM
SSNISTR's Avatar
I have the same issue....
Old 07-07-2008, 09:23 PM
Can you take just the glass/mirror out of the housing without removing the entire mirror assembly off ther car?
Old 07-07-2008, 09:40 PM
Yes you can. Start fom the outside and just slowly pull it out. It is on threaded plastic studs. The metal cross will come out. You have to use some pressure.
You have to use alot of pressure to install it also. You won't break it the glass is tougher than it looks.
DO NOT try to pull the plasic studs out of the mirror backing. they are hard to reinstall without messing them up!
Old 07-07-2008, 09:52 PM
SparkyJJO's Avatar
^^ Oh, good info! I may be able to at least glue the broken mount on my passenger mirror to keep it from shaking so much until I replace it. Thanks
Old 07-07-2008, 10:00 PM
Well I thought of some more info. I can guarantee you the looseness isn't from the ball joint of the plastic stud meeting the mirror backing.
It is probably from the motor or the mount like you guys were talking about. I know Classic Industries sells replacement motors. The dealer will make you buy the whole housing unpainted.
If it is the frame maybe you could repair this. I remember tabs on the plastic housing. Phillips heads holding it together. Plastic bracket holding the motor.
Old 07-07-2008, 10:10 PM
SparkyJJO's Avatar
Well in my case I know the plastic is broken, I can see the broken mount when I peek in there.
Old 07-07-2008, 10:51 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Thanks for the info on removing the glass. I'm looking to remove the motors from mine and delete the associated wiring.
Quick Reply: Driver's side view mirror shaking...
