Dyno #'s for my STS set up
Hey I just had my car dyno'd on a autodyne Super flow dyno It made 335 whp and 323 wtq. I am told these # would be closer to 500 on a dynojet. I have no Idea if this is true or not. According to the guy the C6 Z06's make under 300 on this dyno.I think he should recalibrate it hey.... I am running the gt 67 turbo and ati twin intercoolers.
Just wondering if this is ture? I hope to get out to the track in the next week or so. It ran 14.2 in stock form. I am hoping for low 13's next time out.
The DA here is usually around 5300feet.
Even if the pipes weren't wrapped or anything extra, it would still make way more power, especially with the 67. If you have a stall converter, that could be the culprit or maybe your tranny is slipping or there is a boost leak from a weld. The BOV could be sticking open all the time. There could be a number of things. How many PSI are you running and what type of fuel system?
I dont think there is anything wrong with his setup. He said a c6z06 did like 300whp. So if that was a stock z06 id add another 150whp to you number and then tell people that.
But ya dyno numbers dont mean much,ive ran faster on less whp.
I am running 7psi but it does spike to 9 at first I assume because of the long hose and boost controler.
