larger rims will there be a problem
i have the base model 16 inch Trans Am rims and i wanted to put 18 in the rear and 17 in the front will i have a problem with the Traction Control Sensor or the Speedometer or the ABS sensor? or anything else....
if you run tires in the front that are a different height than the rear your will. The ABS will see that the rears are spinning at a different speed than the front when you apply the brakes slight harder than usual.
Example
16x8 stock = 245/50/16
17x8 = 245/45/17
17x9 = 275/40/17
18x8 = 245/40/18
18x9 = 275/35/18
18x10.5+ 315/30/18
