Plenum Box Exploded! (Procharger Race Bypass info needed)
My metal plenum box exploded today with 14psi at around 6k.
I guess it was my own fault for trying to use plastic procharger bypass..
Going to weld up plenum box all around since welds from procharger didn't even penetrate the metal and strengthen it up some
I am going to get a procharger race bypass....also going to run twin intercoolers for now, but can I weld the race bypass flange in where the plastic bypass connects? or do I just need to mount it on the plenum
btw....I am tuned in speed density....and think I want to recirculate
[QUOTE=AFASTYZFR1;9683746]My metal plenum box exploded today with 14psi at around 6k.
http://www.procharger.com/store/imag.../3FASS_007.jpg Why do you want to recirculate?
Since you cracked the plastic one and the alum one, I would take a good look at your bypass valve. I've heard of several people cracking the plastic plenum at higher boost levels, but I don't recall us ever having a problem with it. Let alone, the alum plenum!
The race valve will certainly help you out. Bob
Never seen one blow up, but those welds dont look like they even penetrated enough.
The motors built to take what you throw at it, what pulley you guys tuning with?
Should I go with vent to atmosphere or recirculate (any chance of unfiltered air entering with the vent to atmosphere.....don't think so but want to make sure)
Car also might get caught in rain
I plan on welding flange above driver side intercooler.....that pipe is steel, right?
I will be giving epp a call in the morning to get one ordered
I'm not sure what the size is to be honest, I'm sure David can chime in.
We saw something like 200 kPa at 6-6200RPMS (I forget) which is about 14.5 psi. Any idea where we will end up at boost wise from 67-6900?
He is running Alkycontrol meth (straight meth) and the kit is cranked up That thing moves a lot of meth!
You will not get dirt in through the bypass as there will always be air blowing out, never in.
