Ladies and Gentlemen, my nitrous is now.......
OPERATIONAL!!!!!!!!!!!!!!!!!!!!!!!!!
I FINALLY figured out why my Accel 375+ was not working.....DO NOT use the fan fuse in the underhood fuse box for a 12 volt "switched power". The ecm turns the fans OFF during start...THAT drove me nuts for a while.
I Flowed the fuel system, put some 116 octane in the cell.....went out and hit the button.....oh baby that big heavy turd MOVES on a 175 shot!!!!!!!!!!
Will go to the track soon.
David
David
MAYBE!!!
I have lost 40lbs since the surgery, down to 300 even.
I dont think it will run the 1/4 with the 4.11 gear and 28 inch slick or drag radial. It sucks up gear QUICK!
Got two options, drop back on gear OR cut my fender openings and put some 295/65 drag radials on it.
MAYBE!!!
3.73s would be the way,possibly 3.55s since tq does not require a bunch of gear...good luck bro and congrads to your weight loss
Good luck David. Finishing my nitrous install this week. Its all mounted and plumbed, just gotta finish the wiring. I am in the same boat you are. With my 27" tires and 4.11s I cross the 1/4 right at 6800. No way Im making it on the spray. Looks like Ill be 1/8th mile till I change a few things.
