Screwed rims question
Actually it probably wouldn't cause any problems. The bead of the tire would cover up the screw holes, the tire seals in the radius and along the foot of the bead, the only possible problem I can see is some air seepage when the car is sitting and it would have to be sitting just right. After the tire is mounted, put a little bit of silicone in the holes and let it set up. I doubt that you will have any problems. just curious though, if you had tire slippage before and had to screw the tires, why wouldn't you have tire slippage now?
Reason i am trying to avoid them now is because i was running bias ply tires with the rims at low psi but now i have switched to a radial and going to try and run more psi
that's what I thought you were doing, but I wanted to be sure. When an open wheel Dirt car gets hit in the wheel you can spin the tire on the rim. If you're running a tube to prevent a flat it will tear the valvestem and then you're done. Oh yea and farmers used to use the same trick with their beat up tractors when pulling heavy **** through fields for the same tire spinning reason. I agree with the silicone on the holes. You would probably be okay either way though.
