408/PT98/Six Speed Build
Old 07-07-2008, 11:11 PM
VENGEANCE's Avatar
Default 408/PT98/Six Speed Build
Were getting closer to dropping the motor in and being in business, so figured id throw up some pics.
Motor
408 Cubic Inch Iron block, half filled (out of casper, courtesy of Kurt Urban)
Callies crank
Diamond Pistons
howards rods
AFR 225's, GM Carb Style intake, custom cam (off Feredays old setup)
solid roller
etc etc
Precision 98mm Turbo
Custom built Kit by RPM
Custom Front Mount Intercooler
Full suspension, tubular K member and control arms, etc
12 Bolt rear with 3.42 geared spool
Built T56 (not as built as it should be, so its probably going to explode after its first two-step launch)
315/60/15 MT DR's
Minitubbed
10pt chromoly cage
Big stuff 3
Turbo
motor at kurts place
Minitub
Brakes, MADMAN offset LCA's
Rear
Alumastar
Weight should be fairly low when its all said and done as well.
Car is being largely built at RPM in Garner, NC. Motor as mentioned before is being put together by Kurt. I have a few short term goals for the six speed, then more than likely Ill put a th210 in it with a 106 and an A2W and see how fast it will really go. Another month or two and we should be in business. Ive got a few vipers and supras to slap in the mean time, as it will remain a true street car.
Old 07-07-2008, 11:36 PM
TINKRD's Avatar
very nice
Old 07-08-2008, 03:17 AM
BlackSuperchargedLS1's Avatar
Nice. Gonna be looking forward to the videos!
Old 07-08-2008, 06:45 AM
venom ws7's Avatar
Sick Build Dom I love it the car will be very mean I'm thinking 850+rwhp on PUMP GAS.
I cant wait for some vids.
Old 07-08-2008, 09:34 AM
TrakDay's Avatar
Where can I get those brakes!?
Old 07-08-2008, 10:07 AM
HUNTER02SS's Avatar
I know of a guy with a Supra that would run ya! Real nice guy as well!
Car looks good. I like the mini's!
Old 07-08-2008, 10:23 AM
LS1TECH Sponsor
DrTurbo's Avatar
Awesome build....
Only thing I see is that turbo will be a HARD sucker to spool with a 6spd.
Old 07-08-2008, 12:55 PM
VENGEANCE's Avatar
Im going to run it on 116 only. Takes a bit away from the "street car" adage (as well as the solid roller does), but Id rather feed the motor the good stuff. Especially since the most Il be driving it is to local meets and maybe to the grocery store
Old 07-08-2008, 01:09 PM
Dunn's Avatar
, regardless, wicked build and hope to see it at FC4Cs one night, should be a mean SOB.
Old 07-08-2008, 06:14 PM
Reject's Avatar
very nice, like ya'lls shop too!
Old 07-08-2008, 10:29 PM
VENGEANCE's Avatar
It will be up there probably every friday after its complete, jeff is a good friend of mine.
Old 07-09-2008, 02:14 AM
firehawk123's Avatar
very nice , from where you got your Minitub .
Old 07-09-2008, 07:19 AM
venom ws7's Avatar
Yeah the Minitube look awesome where can I got those???
With 116 fule the car will be even more meaner.
Man I cant wait for some vids!!!
Good luck with the rest of the build man and keep us posted.
Old 07-09-2008, 11:24 AM
Cmarsh's Avatar
Good luck with the build...I am doing something simular with a built Lt1 motor for the Texas Mile. I'll have 1 mile to spool it
Old 07-09-2008, 12:13 PM
otherwhitemeat's Avatar
My set-up is about the same.....the solid roller has no effect on drivability ...and as DR. Turbo said good luck spooling that thing with a six speed.....I finely hit 20psi at about 6400rpm and at 8000 rpm I hit 30psi plus......the boost curve is like this / and it should be like this - .....its still fast and I still run with 8 second cars. This very large frame turbo need to be loaded with a auto, and your going to loose a lot of boost between shifts around 15psi, and your will need to rev to at least 8500 and should really rev to 9000rpm to make any use of that turbo......
Old 07-09-2008, 03:10 PM
VENGEANCE's Avatar
Wasnt worried about the driveability part of the solid roller, more the adjusting the valve lash often.
The cam was ground to push about 20psi (from what I was told when i bought the stuff, at 19.5lbs of boost this exact heads/cam/intake combo made 1300whp through a glide on the black car, 398ci, 91mm turbo). Through a 6 speed you can guess what that about equates too, so I dont think I will "need" to run quite 20lbs. Ill be turning it to about 8000.
It all depends on what it does on the dyno. I have my opinions, but im not mechanically inclined enough to disagree with anyone. Ill just have to wait and find out.
Old 07-09-2008, 03:22 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,110 Likes on 728 Posts
otherwhitemeat = Jake or Jessie? I'd listen to him, they have been running big turbo combos for a number of years.
Old 07-09-2008, 04:35 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yup, listen to this man....100mm unit on a 6spd car is sick.. He is a billet man now though.......quick, spool F.T.W!!!
Old 07-09-2008, 05:38 PM
Really I never have to check valve lash... just set it and don't worry about it......the 408 will help your spool a bit compaired to my 390??? something....but 20psi on the turbo is doing to give you about closer to 1300hp at the crank then at the wheels.....at 25psi I just barely hang with car that make 1100ish hp......at 30 the car gets crazy....but thats where shifting sucks ***.....and watching them get a car on you every shift blows...Hope new turbo stays in the boost much better so I can recover from the shifts easier and hope it brings the power band down to where the six speed likes to shift better........might haft to put a power glide in the car again to really be street competitive.....
Old 07-09-2008, 06:05 PM
pushinfreight's Avatar
...+2
Quick Reply: 408/PT98/Six Speed Build
