low voltage
low voltage
I'm new and I need some help. I have a bad low voltage problem. In park and neutral the the car has 12 volts., around 11 volt. in drive, and 10 volt. when its in drive and the a/c is on. If I'm driving it and I come to a stop with the a/c on, the volts. drop even more and the car will die if i don't throw it in neutral. I've checked....
- the battery and put two diffrent ones in the car and the volt. didn't chang
- changed the alternater 3 times . Its a 140 amp now and it does charge. Its never killed my optima
- no underdrive pully
- volt. reading at the battery is the same as the gauge in the car
- checked all visible grounds
- and it doesn't have a stereo
There is a ground on the passanger side engine mount to the block. Another one from the ICM to the fender. One from the Battery to the fender... and... that's it? I forget.
Check the exciter wire from the alt to the pcm, and the battery to alt power wire.
usually a toasted regulator will send your charge level through the roof when you are driving though. i know when mine went out it would reach 18v! when you checked your grounds, did you check the actual ground point? paint or rust will definitely create a poor ground issue.
