will the truck oil pan work in a fox body with the aje k member?
Old 07-10-2008, 12:58 PM
94 guy's Avatar
Default will the truck oil pan work in a fox body with the aje k member?
thanks
Old 07-10-2008, 03:53 PM
mulletnotch's Avatar
Ya I believe so. The sump just hangs awful low in my opinion.... Use the F-body pan, why chance your motor for a $200 part?
Old 07-10-2008, 04:03 PM
97'-lt1's Avatar
Yes it will clear..But as stated hangs pretty low...If I remember right tirefryin_s10 used a truck pan in his setup..Not a 100% on which k member he used though...
Old 07-10-2008, 05:01 PM
94 guy's Avatar
well i have both pans. i would like more capacity if i could have it.
Old 07-11-2008, 07:52 AM
97'-lt1's Avatar
The truck and car pans are both 6qt. pans..
Old 07-11-2008, 12:30 PM
94 guy's Avatar
then why are the pans different
Old 07-11-2008, 12:59 PM
lt4malibu's Avatar
LS1Tech 20 Year Member
truck pan needs to clear the front diff in the C/K truck...
Old 07-12-2008, 04:06 PM
LS_STANG's Avatar
I put the truck one in on my swap for one day and it is way to low for normal safe street driveing
Quick Reply: will the truck oil pan work in a fox body with the aje k member?
