Car is sitting higher?
I just put the Moser 9" in my car. I was looking at the car the other day, and it seems like the back of the car is sitting higher than before. Is that normal? I have the stock springs with the isolator removed.
Have heard that the axel tubes are a little larger in diameter which causes a larger gap from the tire to fender well. I know on my buddies Dana 60 that was the case so it must apply to the 9s as well.
Well that sucks. Anybody know of a lowering spring that's not too firm? If I recall correctly the Eibach drag spring also makes the rear sit higher, so I want to avoid that, but I do want something that's going to work well at the drag strip.
Maybe try a set of rear Strano springs with the stock isolators, I think the Strano springs have just a little more spring rate than stock, which may also help with the added weight of the 9''. Just a thought.
